  #1
Old April 18th, 2008, 11:17 PM
nbaffaro nbaffaro is offline
Default Mercury 110 9.8HP Water Pump Replacement
My water pump on my Merc 110 9.8 ate all of the vains off of the water pump. How do i get the shaft out to replace these parts. It is in the picture. the long shaft that goes out of the picture (the one of the right)
Thanks
Nick
  #2
Old April 19th, 2008, 09:05 AM
Laddies Laddies is offline
Default Re: Mercury 110 9.8HP Water Pump Replacement
You don't need to remove the shaft only the imp. hub use a punch and tap the hub in the clockwise irection to loosen it on the key, then pry it up out of the housing. The thing you need to do it find as many pieces of the imp. as possably so they don't plug the water passages.
  #3
Old April 19th, 2008, 06:53 PM
jbjennings's Avatar
jbjennings jbjennings is offline
whatever you do, don't check the lower unit oil or lift up the water pump housing and look at the driveshaft, you probably won't like what you see judging by the part of the driveshaft you can see. Seriously, If the oil isn't too bad just change it a lot. It's a pain to fix that driveshaft but you might want to try the speedisleeve method mentioned recently in a thread.
Good luck,
JBJ
  #4
Old August 9th, 2008, 09:15 PM
grantcall grantcall is offline
Quote:
Greetings from Australia, saw your questions on website, had a few of my own. The 7.5 & 9.8 Mercury's come in short and longshaft. My old 9.8 has a two piece drive shaft. By removing the 8'' upper drive shaft, the engine can be re assembled as a short shaft. This upper 8'' part is getting a bit old and rusty, any suggestions as to how to obtain a replacement? New. secondhand, or fabricate. Thanks. G.N.
  #5
Old August 11th, 2008, 07:10 AM
Greetings from Australia, saw your questions posted on web site had a few of my own. The 7.5 and 9.8 Mercury's come in short and longshaft. My old 9.8 has a two piece drive shaft. By removing the 8" upper drive shaft the leg can be reassembled as a short shaft. This upper 8'' of the drive shaft is getting old and rusty and maybe a bit thin. Any suggestions as to how to find a replacement? New, secondhand, or fabricate. Thanks. G.N.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 110 9.8HP irving@altrim.com Mercury & Mariner Outboards 1 November 7th, 2007 05:15 PM
Mercury 9.8hp 110 runky325 Mercury & Mariner Outboards 3 June 25th, 2007 10:14 AM
8hp Yamaha water pump replacement?? nitroturbo4u Yamaha & Suzuki Outboards 1 August 1st, 2004 01:48 PM
Mercury water pump replacement ZaQ Mercury & Mariner Outboards 1 July 30th, 2004 07:40 PM
'68 merc 110, 9.8hp fuel pump question LanceM Mercury & Mariner Outboards 0 July 14th, 2003 10:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
