Hey first post
95 evinrude 115
alarm sounds consistanly at times. sometimes when boat has not started yet for the day.
changed water pump and thermostats,
after done before starting alarm sounded, unplugged both temp sensors in heads
still goes off, unplug vro, still sounds unplug oil tank and sound quits,
have factory service manual but says nothing of spec for system, has a wiring diagram, tan wire tied to two temp sensors in head, vdo and oil level, i am master gm tech master ase tech and can not believe factory book not more specific, for me to understand is poo
so the same circuit conected in series does three different things, so for this to happen has to be looking a resistance to ground? i assume, but how does it make it beep every 40 seconds or 1/2 sec on and 1/2 sec off.
alarm has three wires. purple, black and tan. purple has 12volts and black has ground. tan is grounded when horn sounds continusly
any help would be greatly appreciated.
95 evinrude 115
