  #1
Old April 17th, 2008, 06:29 PM
dmiller40 dmiller40 is offline
Default 1972 Evinrude 6HP cooling problem???
I just bought this motor recently. It's a 1972 Evinrude 6HP. I replaced the water pump impeller (the old one was not broken, just old), and rebuilt the carburator. It runs smooth and pumps plenty of water, but the first time I ran it (after replacing the impeller) I noticed that the engine was not heating-up. I removed the thermostat cover and discovered that the thermostat was stuck open. I then replaced the thermostat with a new one. With the new thermostat installed, the top of the block, next to the cylinder head, gets very hot. The cylinder head does not get hot, only warm, and the block around the lower cylinder is only warm. I am concerned about the temperature around the upper cylinder. I can not hold my finger on the top of the block for more than a second.
I removed the new thermostat and ran it that way (no thermosat) and again, the block stays cool.
Any suggestions? could I have a cooling blockage in the block, or is this normal? I don't want to damage the engine.
  #2
Old April 17th, 2008, 06:50 PM
F_R F_R is offline
Default Re: 1972 Evinrude 6HP cooling problem???
Does it sizzle water if you sprinkle some on it? That's too Hot. (Poor-man's temp gauge). Water flows through the powerhead in two paths. One path may be clogged. It's been too long for me to remember where the likely restriction may be.
  #3
Old April 17th, 2008, 07:59 PM
No, it doesn't sizzle water, just too hot to touch.
  #4
Old April 18th, 2008, 10:07 AM
OK, did a little more investigating.I think I might have a partial blockage in the upper cylinder cooling passageway. Here's what Iv'e done so far:
I removed the thermostat cover and thermostat, then started the engine and ran it at low speed for a short time with the thermostat cover removed to observe the water flowing into the thermostat housing. There are two holes leading into the thermostat chamber. I'm assuming that each hole is the cooling passage for one of the cylinders. Here is what I observed:
  • The lower hole in the thermostat chamber was spraying a stream of water.
  • I couldn't tell if any water was spraying from the upper hole, because of all of the water coming from the lower hole.
  • When I plugged the lower hole with my finger, the upper hole began spraying water.
Does this sound normal? If I have a partial blockage in the block, how can I clean it out? Any recommendations?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
cooling pump problem 6hp evinrude ptheroux Johnson & Evinrude Outboards 3 April 16th, 2006 05:30 PM
Johnson 6hp 1974 cooling problem alussow Johnson & Evinrude Outboards 19 November 16th, 2004 04:32 PM
1980 Evinrude 6HP Cooling Problem Simonaltman Johnson & Evinrude Outboards 5 June 14th, 2004 11:08 AM
1996 johnson 6hp cooling problem Sherman Johnson & Evinrude Outboards 5 June 1st, 2004 12:31 PM
6hp cooling problem 2637042 Johnson & Evinrude Outboards 4 April 5th, 2004 08:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
