rectifier lead assembly 1978 johnson 70 hp ?
moored3
I was cheching the wiring on the motor 78 johnson 70hp and found the red wire on the rectifier completely burned into . Just what function does th e rectifier serve. the motor still ran just could not get it to idle.
ezeke
Re: rectifier lead assembly 1978 johnson 70 hp ?
The rectifier converts the AC current into direct current for charging the battery. It is good practice to replace the rectifier when damaged in any way. The rectifier is a system of diodes that allow voltage to run in only one direction.
If the diodes are damaged, the battery voltage can reach the ignition system and destroy the components.
moored3
Thanks, can this effect the way the engine rus in anyway
ezeke
Yes. If you don't replace it, map the connections and disconnect it from the terminal block.
