AGENT 37
- Mar 2, 2007
- 319
Nope, not an explosives test (yet)
2000 Yamaha T50
I removed the electric tilt and trim motor for overhaul and cleaning with the motor in the supported up position. (it worked but looked like crap.) I reinstalled it and it was running slow (labored, slow turning motor) going up. We played with manual relief valve and ran motor with the valve open to make sure that the air was bled from the system. Now with the manual relief valve fully opened up I can not manually lift the motor past the trim range. It goes up and down in the lower range without trouble but I can't get it to fully raise. I wanted to just replace the electric motor and service the fluid again. The book isn't very helpful as far as troubleshooting goes now. What I ought ta do?
2000 Yamaha T50
