Finally got to borrow compression tester today, rushed home let the dogs out and started pulling plugs. Here is what i found, all 4 cylinders had 60 psi +/- 1 or 2 psi. So can this be or do i need to retest with a diffrent tester, this one belongs to a bus mechanic where i work and looks ok! Motor is 1983 j90tlcte. Last time out it ran 44.1 mph at 5600 rpm with 13.25 x 17p alum prop, i have since raised motor one hole but have not ran it. Thanks 4 all comments!
