First a little background.......
I have a 1993 Evinrude 50 hsp that I bought last fall. The previous owners had a problem with the oil injection and blew the motor. They had it repaired at Cabelas in 2006 and said they have not used it since. They installed 2 new pistons. (one of them was .030 over sized) The instructions on the repair invoice said to use double oil the first 3 tanks. (18 gallons) At the time I bought the boat, the compression was either 128/130 or 148/150. (I don't recall which...although at the time a mechanic friend of mine told me that was good.)
After finding out the motor had been repaired, I lowered my offering price considerably. (The negotiations are a story in itself so I will spare you that part.) The worst case scenario is that if the motor doesn't hold up, I can sell the boat and trailer and easily get what I paid back out of it.
Question 1.
Now... for the 1st 18 gallons while running double oil for break in, I will keep the oil injection hooked up because I will also be running 50:1 in the tanks. The question...based upon the above scenario would you keep using the oil injection system or bypass it and just mix oil after the break in period? (The pump was replaced when the motor work was done in 06)
Question 2.
I've read that many people on this site use Pennzoil 2 cycle oil with no problems. On my previous boats, I used nothing but the OEM oils for the motors I had. After checking my local marine dealer and finding a 28.00 price tag on a gallon, I decided that Pennzoil would probably suit me fine. .
At Bass Pro and Wallyworld I've seen 3 types of Pennzoil
1. Pennzoil Marine XLF Extended Life
2. Premium Plus
3. Full Synthetic
The first 2 are synthetic blends. I'm kind of confused as to what the real difference is between those 2. The XLF says it is for seasoned motors but then again it says it is also good for new high hsp engines. Here is a link to their web page. (Scroll up and down to see all 3 types)
"http://www.pennzoil.com/products/marine/index.html#PremiumPlus"
Does it really matter which one I use in my case? Wallyworld doesn't have the full synthetic but they have the other 2. Bass Pro has all 3. The XLF is on sale right now for 9.88 a gallon at BP so I bought 2 gallons last weekend. (The XLF and Premium Plus are normally priced the same.) Can anyone shed any light on the 2 types of synthetic blends and what your recommendation is for my motor situation?
Thanks
Question 1.
Question 2.
2. Premium Plus
3. Full Synthetic
Thanks
