  #1
Old April 15th, 2008, 11:57 AM
MN_fisherman MN_fisherman is offline
Default Pinion starter gear for 9.5 Evinrude
Does anyone have any tricks for improving the function of the pinion gear on these motors. In order for the nylon pinion to rise up and engage the flywheel you have to really jerk on the starter rope which sort of bothers me since I prefer to pull the rope slowly until I feel the recoil engage then let 'er buck. Under the pinion there is a spring which I assume has something to do with the function of the pinion. The teeth are on the pinion are worn but there are no other noticeable cracks or defects. What I'm wondering is if anyone here knows how to make this set up work better. Thanks in advance.
  #2
Old April 15th, 2008, 12:58 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: Pinion starter gear for 9.5 Evinrude
The spring that you speak of should be clamped around and into the groove that you'll see under the bendix (pinion) gear (part of the bendix gear). This creates a slight friction upon the gear that causes it to rise when rotated.
  #3
Old April 15th, 2008, 02:27 PM
Thanks Joe I suspected that spring served a purpose, right now its basically just sitting freely under the bendix. I'll see if I can figure out how to clamp the spring into place under the bendix like you describe. I recall the spring is spit at the wide end (the part that goes under the gear). I can imagine how this could create enough friction to ride up and engage the flywheel.
  #4
Old April 15th, 2008, 10:16 PM
Thanks again Joe, did what you said and she works like a charm!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starter Pinion Gear imported_Lana Johnson & Evinrude Outboards 3 March 10th, 2007 02:05 PM
evinrude pinion gear cullracing Johnson & Evinrude Outboards 2 August 15th, 2006 09:59 AM
Starter pinion Gear on 1989 Evinrude 88 horsepower motor Bobby Autry Johnson & Evinrude Outboards 0 August 10th, 2006 08:39 PM
1989 Evinrude model E88MSLCER starter motor pinion gear Bobby Autry Johnson & Evinrude Outboards 1 July 30th, 2006 11:34 PM
Pinion gear needed 40 hp Evinrude Merrill Johnson & Evinrude Outboards 1 July 23rd, 2005 06:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
