  #1
Old April 13th, 2008, 08:41 PM
SiLiconD17 SiLiconD17 is offline
Default Yamaha EL40 40hp gear case issues
Hello, I just got done dropping the lower unit and replacing the impeller and water pump housing gasket. I got the gear shifter linkage put back together just how it was before, and it seemed like the splines on the driveshaft met up with what was above. When I run it, it will go into reverse fine and then back into neutral, but it seems whenever you go into forward there is a delay until it shifts, and when you bring it back to neutral it makes a grinding noise pretty bad. I even noticed sometimes it didn't seem to go into neutral and still seemed to be in gear even with the control in neutral. It seems to be grinding like one of the splines aren't catching or something when you put it into forward and take it back out. If you manually rotate the prop with your hand (turned off obviously haha), it makes a clicking noise. Anyone have any ideas? Thanks!
  #2
Old April 14th, 2008, 10:34 AM
Ray Neudecker Ray Neudecker is offline
Default Re: Yamaha EL40 40hp gear case issues
When reinstalling be sure on a Yamaha that both the gearcase and shifter are in neutral.
  #3
Old April 14th, 2008, 10:44 AM
Should I go ahead and drop the lower unit again, make sure it's in neutral and that the control is in neutral, then reinstall? Thanks for the info.
  #4
Old April 15th, 2008, 08:20 PM
Smile Re: Yamaha EL40 40hp gear case issues
that would be my suggestion.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60 Evinrude 40hp, gear case parts Evinrude Boater Johnson & Evinrude Outboards 4 February 22nd, 2008 12:58 PM
Yamaha Gear case reassembly Thumbtack Yamaha & Suzuki Outboards 0 February 6th, 2008 12:17 PM
1990 Yamaha 40hp carb issues... SiLiconD17 Yamaha & Suzuki Outboards 3 September 8th, 2007 08:41 PM
1961 Evinrude 40hp lower gear case repair carewood Johnson & Evinrude Outboards 4 November 17th, 2006 10:14 PM
Yamaha 200 Gear Case Noise and Vibration. steamin53 Yamaha & Suzuki Outboards 8 August 26th, 2005 08:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
