  #1
Old April 13th, 2008, 07:41 PM
kentrx1 kentrx1 is offline
Default mariner 60 hp charging problem
noticed last season that engine would run fine but had to charge the battery a couple of times toward the end of the season. battery checks out fine, not using lights or anything to drain the battery, and i started testing charging today. on a charged battery, the voltage stayed around 12.7 volts when it was running and did not flutate when i sped the engine up. i anticipated the voltage would increase as the rpms went up so i am wondering if the voltage rectifier/regulator is faulty. i did flip the battery disconnect while it was running for a couple of seconds to see if the engine would die, and it did not sound like it affected it any----but only left it that way for a couple of seconds. i think it is a 1991 mariner sn 07054043 the best i can read it. the first letter could possibly be a c. what i think is the regulator is at the back of the engine mounted in the bottom of the case. it has several wires running out of it and around the side of the engine. they are separated into 2 wiring groups and they have bullet plugs on the end of them. am i correct in thinking that if the stator was defective, when i cut the battery disconnect the engine would have died? thanks for any help offered!
  #2
Old April 13th, 2008, 08:01 PM
Silvertip Silvertip is offline
Default Re: mariner 60 hp charging problem
If the regulator/rectifier wasn't fried before you flipped the switch, it probably is now. You must never run the engine with the battery disconnected. If the voltage on the battery did not rise when you reved the engine the charging system is not working. The engine will run however with the battery disconnected since it generates it's own ignition power without a battery.
  #3
Old April 13th, 2008, 08:12 PM
i did not flip it until after i had determined the rpm of the engine had no effect on the voltage at battery. i flipped it only for a sec to see if engine would die b/c i felt if stator was defective engine would sputter.
  #4
Old April 13th, 2008, 10:05 PM
Laddies Laddies is offline
Seldom does the battery charging part of the stator fail, you need to test the regulator
  #5
Old April 13th, 2008, 10:30 PM
is there a way to check it other than measuring the battery voltage while running? and if i need to replace it, i have noticed the replacement parts listed do not look like the one i have installed. it is much more rectangular and has longer leads on it than the almost square ones shown with short leads. do i just splice it in and only use one mounting screw?
  #6
Old April 14th, 2008, 08:57 AM
Yes, you can ck them with a OHM meter, we have to know how many wires it has to give you the test
  #7
Old April 14th, 2008, 09:25 AM
the boat is at my lake home. i took a picture of the part and there are at least 5 wires----but could possible be more as the picture might conceal another one or two.
  #8
Old April 14th, 2008, 10:08 AM
The regulator shown here is the early style the early ones were square with clear potting and the wires came out the front, the replacements look quite alot differant but last much longer.
  #9
Old April 14th, 2008, 10:39 AM
Thank-you sir!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
85 Mariner Not Charging mikecojoe Mercury & Mariner Outboards 0 April 7th, 2008 12:51 AM
2001 115hp fourstroke charging problem-Update:Problem Solved sdsaw Mercury & Mariner Outboards 7 March 15th, 2008 05:06 PM
Mariner 150 not charging sjp649 Mercury & Mariner Outboards 4 July 13th, 2007 05:42 PM
60 hp mariner charging problem amot69 Mercury & Mariner Outboards 2 August 16th, 2006 03:49 AM
60 hp Mariner not charging amot69 Mercury & Mariner Outboards 2 August 15th, 2006 05:55 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
