  #1
Old April 13th, 2008, 07:36 PM
Big Bubba Big Bubba is offline
Default Primer Bulb hardness on Evinrude 88 SPL model# E88MSLCER?
Hello to all of you this evening,
I was wondering how hard should the fuel bulb comming off the fuel tank should be? Is it as hard as a rock or is there some give if pumped up right when you pump the fuel bulb up and will it hold that pressure for a few hours. I have an Atwood Fule primer bulb and after a while will lose its hardness until I pump it back up then it will pump up fine but has some give to it, very, very, very little give to it then if I come back to the boat in about 1 hour I have to pump it back up. Is that normal? How hard should the bulb pump up, rock solid hard or just frim with some give in the bulb? Thanks Bob
  #2
Old April 13th, 2008, 07:48 PM
Silvertip Silvertip is offline
Default Re: Primer Bulb hardness on Evinrude 88 SPL model# E88MSLCER?
This is a topic that is so simple yet people really get wrapped around the axle with. First, the primer bulb needs to be pumped only on the initial start of the day and even that's a maybe. If the boat has sat for a few days, firm it up and start the motor. It should be fine for days. Understand that once the engine is started, fuel is being sucked through the bulb -- not forced through it. Therefore it begins to go soft the minute the engine starts, and it will stay that way. The bulb as an inlet and an outlet check valve that is less than a precision fit but since it has to serve such a simple purpose (filling the carb bowl) it can and probably will leak down over a few hours. Some will leak down quicker than others. The only time for concern is if it gets sucked flat with the engine running, or if you can't firm it up at all (it doesn't pump fuel).
  #3
Old April 14th, 2008, 01:04 AM
Dave_A Dave_A is offline
cover the bulb on the outside with motor oil...
Worked for me (to soften it up), anyhow...
  #4
Old April 14th, 2008, 09:29 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
once the motor starts it will become some what soft. if it collaspes, sucks in on it's self or becomes flat, there is a restriction, between it and the tank, usually the tank vent, or anti siphon valve.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Fogging 1989 Evinrude V-4 SPL model# E88MSLCER Bobby Autry Johnson & Evinrude Outboards 5 October 30th, 2006 09:20 AM
Smoking 1989 Evinrude V-4 SPL model# E88MSLCER Bobby Autry Johnson & Evinrude Outboards 2 October 10th, 2006 07:38 PM
Collapsed primer bulb on 4 stroke 9.9 Evinrude. MikeMo Johnson & Evinrude Outboards 7 May 31st, 2004 04:50 PM
85 120hp Evinrude primer bulb problem Luna Sea Johnson & Evinrude Outboards 4 July 19th, 2002 01:16 PM
Primer bulb does not achieve hardness daschtick Force & Chrysler Outboards 4 April 10th, 2002 07:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
