i have a 85hp force that only runs on one cylinder
chrisdrybread
i have an 85hp force that only runs on one cylinder i swiched the wire from one pack to the other and it fired what is the problem thanks
gerrym
Re: i have a 85hp force that only runs on one cylinder
I am having the same problem with a 50hp. Did you figure it out?
chrisdrybread
no but im trying to figure it out uif you find any thing out can you tell me ill do the same thanks chris
Keniki
Pull all 3 plugs and check to see if you are getting fire to all when cranking. If yes, check the compression ...may be a cylinder score problem
john from md
Folks,
There are literally thousands of posts on this forum relating to no spark. Do some searches under differnt terms or search for Frank Acampora's posts or john from md's posts as they have lots of info.
After you do that, and have done some basic troubleshooting, then come back and ask your questions. When you do, indicate what the problem is and what you have done thus far.
John
