freddyray21
- Jun 10, 2006
- 2,460
I am resealing the lower unit in this one and like to never got the shift shaft bushing out. This one looks a bit different from the other two or three I have changed. The end sticking out of the housing is tapered a bit. It almost looks like a collar for the seal to fit around. The end that was inside the case is flat. When I pulled it out there was only a fiber washer and no o ring in the case. My questions are two. Did they put the bushing in upside down the last time this was apart? Should there be an o ring and a fiber washer to seal it or just the washer?
