  #1
Old April 12th, 2008, 09:34 PM
jwilkey84 jwilkey84 is offline
Default mariner pee hole not peeing
I have a 40hp mariner tiller that worked fine for the last two seasons, but I put it up for the winter, it was covered all winter, and now the pee hole doesn't seem to spit any water. There should always be water coming out of there right? there is water coming out of the exhaust holes below the cowl, but no water flowing out of the actual pee hole. I ran the boat for a couple of minutes, even at full throttle for a while, but it didn't seem to get hot to the touch. What could my problem be, I mean what could have happened while it was just sitting? Could the tell tale be plugged, could the tstat be bad? The hole for the tell tale is drilled into the bottom end of the water compartment, which tells me that possibly there is no water getting to my motor since nothing is coming out of the pee hole. Just looking for some ideas, thanks. I really like this motor and dont want to get into the rush of spring fishing here in iowa and ruin a motor.
  #2
Old April 13th, 2008, 07:00 AM
Laddies Laddies is offline
Default Re: mariner pee hole not peeing
Run the engine and take a peice of wire or weedwacker cable and try to rod the telleate out or blow it out when running if you stillget no water you need to ck the impeller
  #3
Old April 13th, 2008, 10:07 AM
wouldn't the water coming out of the exhaust holes tell me the impeller is working?
  #4
Old April 13th, 2008, 10:24 AM
Yes, the water coming out of the exhaust is a good indication that the pump is working as far as thermostat and the rest of it you neglected to tell us the year or model or serial number, so it's hard to tell.
  #5
Old April 13th, 2008, 11:52 AM
buggiedad_67 buggiedad_67 is offline
if running a weedeater string dont work, you can do what i did, if you have a compressor, start engine and blow air up the tell tale hole and that should do it, i had to take the hose loose from the block and found a mud dobers had started a nest there cleaned it, started and used compressed air, it worked,
__________________
if you dont know it, learn it, if you cant learn it, leave it alone!!!
  #6
Old April 13th, 2008, 10:04 PM
bigwheeler bigwheeler is offline
Hey, had the same problem about a week ago. there are several problems you could have. first try clearing the tube with weedeater string, if it all seems clear, you could have a stuck thermostat or (poppet vavle) if your model has one. Also, just because there is water coming out of the lower unit tell-tale doesnt mean that your impeller is completely fine it could be in tact enough to pump but damaged enough not to be putting enough pressure up to the head, water pumps generally will go bad when stored especially in winter months and generally require replacing every two to three years.
After i replaced my water pump it would only pump out drips so i took my water hose and held it tight to the pee hole and put back pressure on it until i got water coming out of the suction holes, after i did that it worked great.
  #7
Old April 14th, 2008, 10:34 PM
Just for the record, the motor is a mariner 40BM, and there are also these numbers on it: 676BS and 000449. I took the tell tale hose off and tried to blow air through it with my mouth, nothing. So I took a zip tie (only thing I could find in the back of the truck) and reamed it out, I did feel something hard that eventually broke free, I am guessing a bug or mud. Anyway, now I can blow air through it, and I am confident that was the problem, so I will find out tomorrow when I take her to the lake.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pee hole not peeing?? barbwire44 Johnson & Evinrude Outboards 18 August 12th, 2007 10:12 PM
tell tale hole (weep hole) on 1986 Merc Mariner 75 eastshores Mercury & Mariner Outboards 1 May 14th, 2006 06:55 AM
Mariner Water Pump, Pressure, Peeing, Thermostat? CiBe Mercury & Mariner Outboards 0 July 17th, 2003 06:05 AM
6 hp Evinrude "pee hole" not "peeing" theboat Johnson & Evinrude Outboards 5 April 8th, 2003 06:33 PM
25 HP Mariner not peeing! Hoss from Bama Mercury & Mariner Outboards 4 April 22nd, 2002 09:56 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
