  #1
Old April 12th, 2008, 06:37 PM
Mike McGoffin Mike McGoffin is offline
Default Starting "new" 1986 Evinrude 6 hp
I have just purchased a 1986 model Evinrude 6 h.p. It was used once for 6 hours when it was brand new. The owner then died and the motor was never used again and has been in storage ever since. It is in absolutely new condition. What steps do I need to take before attempting to start this motor?
  #2
Old April 12th, 2008, 06:41 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Default Re: Starting "new" 1986 Evinrude 6 hp
Welcome to iboats.
This is from the FAQ, and worth a read for you
http://forums.iboats.com/showthread.php?t=158086
Let us know how you do
__________________
Chris
  #3
Old April 12th, 2008, 06:50 PM
Thanks, Chris!
  #4
Old January 31st, 2009, 04:16 AM
Sandhammaren05 Sandhammaren05 is offline
Banned
Talking Re: Starting "new" 1986 Evinrude 6 hp
Submerge gearcase in at least a foot of water then try to start it. If it runs, fine. If not then the carburetor openings may be plugged with gas turned to varnish, must be cleaned in gunk and blown out with air gun. Then, check gearcase to see if oil is orange or black. Whiteish indicates water in oil, bad seal on propshaft or driveshaft.
Quote:
  #5
Old January 31st, 2009, 08:12 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
replace all the fuel lines with alcohol resistant fuel lines, due to ethanol deteriorates the inside of the old lines, clogging the carb.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old January 31st, 2009, 11:00 AM
Vic.S's Avatar
Vic.S Vic.S is offline
I think I'd fill with fresh fuel, treat as new and solve any problems if you find them.
BUT a new pump impeller would be more than sensible. That's mentioned in High Trims link I feel sure.
Also note it should run on 50:1 even if the manual or decals say 100:1!
Standard plug recommended is now QL77JC4 and the gap now recommended is 0.030" ( but i only discovered this recently and still have the original QL77J4 in mine and still gapped at 0.040")
For continuous high speed operation they still recommend the surface gapped QL78V it seems.
The only problem I have had with mine is that the grommet at the top of the water tube gets squeezed over the top of the tube by corrosion until it cuts off the water flow.
__________________
If it aint broke dont fix it!
If all else fails read the manual
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Merc "Black Max" 200 - Question about "warning beeper" iamkarl Mercury & Mariner Outboards 7 June 23rd, 2004 05:27 PM
Evinrude Yachtwin "6" - Intermittent Starting lsmit2 Johnson & Evinrude Outboards 1 October 31st, 2003 10:57 AM
"Quick Start" & "fast idle" questions on '97 Evinrude 11 StAugVol Johnson & Evinrude Outboards 3 April 16th, 2003 07:29 PM
Starting "87" 70 hp Evinrude svangui1 Johnson & Evinrude Outboards 2 May 5th, 2002 04:45 AM
Long time NOT running 62 evinrude ""help john""!! mezman Johnson & Evinrude Outboards 7 March 19th, 2002 01:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
