  #1
Old April 12th, 2008, 04:08 PM
pancakes pancakes is offline
Default mercury 150 efi tachometer
can anybody tell me how to start trouble shooting an erratic analog tachometer on a mako195 dc with a merc 150 efi. the gauge does respond a little bit but is doing this really weird bermuda triangle thing where it jumps all around.
thanks for the help
  #2
Old April 12th, 2008, 11:06 PM
big_b16 big_b16 is offline
Default Re: mercury 150 efi tachometer
I had a similar problem. I tried the expensive route (new VRR) first, but that didn't fix it. Next attempt I replaced the tach and all was well again. Mine would jump around for no reason sometimes, even when the engine speed didn't change. I could tap on the tach and it would sometimes work alright for a while. Then act up again. In the end...was a bad tach. Hope this helps.
  #3
Old April 14th, 2008, 12:30 PM
j_martin j_martin is offline
If the tach has a pole or phase select switch, trying moving it to all the other positions, then back where it was. Sometimes the switch gets dirty.
If your battery is charging, and you have a dual regulator system, try moving the grey wire to the other regulator. One regulator (with the tach connected) could be bad. been there, done that.
hope it helps
John
  #4
Old September 18th, 2008, 12:35 AM
jackflash jackflash is offline
Unhappy Re: mercury 150 efi tachometer
Quote:
My tack done the same as you said took to shop and they said it was the tack. I replaced the tack and now it does not work at all. I also replaced the (VRR) but it still don't work. Can you help me.
jackflash
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
tachometer for a 75 hp mercury outboard boating made fun Mercury & Mariner Outboards 1 March 31st, 2008 07:12 AM
Mercury 800 '82 tachometer calibration? fishdog4449 Mercury & Mariner Outboards 1 September 25th, 2007 10:26 PM
Tachometer Mercury Classic 50 Basstech Mercury & Mariner Outboards 3 March 9th, 2006 02:33 PM
tachometer for 15 hp Mercury RI_Bay_fly Mercury & Mariner Outboards 0 August 14th, 2002 07:15 AM
40hp Mercury Tachometer Netsloth Mercury & Mariner Outboards 3 August 9th, 2001 04:02 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
