  #1
Old April 12th, 2008, 03:23 PM
pianorealm pianorealm is offline
Default Evinrude 30hp Starting Problems....STRANGE!
Hi. I have a 1991 Evinrude 30hp pull start outboard. It was on a boat I bought recently. I have had a great deal of trouble starting it. Strange thing is I found out by accident a 'sort' of way to start it: Position remote throttle at idle....purge extra fuel a couple of times.....pull starter rope several times...WON'T start...not even a flutter! Position the throttle to 1/2 open...leave for 1/2 hour to one hour......pull again....STARTS INSTANTLY! Can throttle back to idle no problem. Will start easily now if warm, even if throttle is in idle position. Leave it more than an hour and I have to go through the whole procedure again!!!!
Any help would really be appreciated!
Regards, Howard
  #2
Old April 12th, 2008, 04:53 PM
JB's Avatar
JB JB is offline
Default Re: Evinrude 30hp Starting Problems....STRANGE!
Please explain "purge extra fuel".
Sounds like you are flooding the engine on the initial try to start it.
__________________
RED SKY at night. . .
JB
  #3
Old April 12th, 2008, 05:02 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
cold start procedure. pump hose bulb till hard, neutral, throttle to start position, not idle, as far as it will turn in neutral, choke, pull. should start 2nd or 3 try. if not do not choke any more.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old April 13th, 2008, 03:47 PM
Thanks for your replies.
Sorry, I've not explained properly. I'm referring to the plunger (like a choke) on the engine. The manual says when starting from cold it needs to be pushed in an out a couple of times (extra fuel to carbs) I've also tried to start without this procedure...still no joy!
Regards, Howard
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starting issue (strange symptom) jrs151 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 August 24th, 2007 11:07 AM
STRANGE starting problem 78 35hp evinrude jkarr Johnson & Evinrude Outboards 8 December 19th, 2006 09:59 AM
30HP Evinrude Starting Problem... sjohnson111 Johnson & Evinrude Outboards 6 January 9th, 2005 01:12 PM
1998 60hp Evinrude strange starting phenom. joebologna Johnson & Evinrude Outboards 3 February 18th, 2004 01:17 PM
30hp Evinrude starting problem Donald Boat Topics and Questions (not engine topics) 2 May 30th, 2001 07:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
