reelfishin
- Mar 19, 2007
- 3,043
I picked up a pretty much turn key boat with a Merc 120, I have two issues with it. It runs smooth and has 140 psi compression on all 4 and excellent oil pressure but lacks power in my opinion. It may well be all that it was every capable of too. It will cruise at 30-35mph, at wide open trottle, it don't have a tach or speedo, so the rpm is a guess right now. I get 33-34mph on my GPS. I like the boat and it's in really nice shape with no rot anywhere. Is there a motor swap option with that drive? Did merc ever use the ford 2.3 OHC? I'd prefer a more modern motor if possible. This is a sea water cooled motor and while it looks fine now, I am sure that over it's 38 years it probably has some internal corrosion. (I had an earlier Merc 110 that had the cylinder head rust away just behind the thermostat housing or water neck, and that was a pretty well maintained motor). I got this boat super cheap, at $500 for a running boat and trailer with a full tank of fuel that I was able to drive home to the local ramp here to load there has to be at least that in parts. It came with 4 or 5 new spare props, a new bimini top, partial enclosure and all new seats. Everything works, with the exception of the tilt up function.
The other problem is that the power tilt won't always go all the way up. It's not hydraulic, since it when it works, it works fine, but when it won't, it won't raise at all. The pump and cylinders both look new. Is there a safetly switch somewhere or am I just missing something here? It worked fine when I first brought it home, and it works fine on the trailer, but it wouldn't work the other day on the water. It's not running at all in the up or trailer positions. It has three buttons for the controls, none are marked.
I see a limit switch outside on the unit, but I don't see that shutting the whole 'up' circuit down. I tried it in neutral and forward too with no change. Is there another switch or could the main controls switches be getting intermittent? Is there a simpler set up or something more modern to control the tilt with other than the three button set up?
