just checking...1994 Mercruiser 5.7 Alpha uses a 14" flywheel, correct?
B baja power Petty Officer 2nd Class Joined Apr 7, 2004 Messages 116 Feb 29, 2008 #1 just checking...1994 Mercruiser 5.7 Alpha uses a 14" flywheel, correct?
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,461 Feb 29, 2008 #2 Re: flywheel size 1994 Mercruiser 5.7 Ayuh,..... Probably........ Reach down under the Starter,+ see if it's retaining bolts are Straight across, or Staggered....... Staggered is the 14" flywheel.....
