Replacing prop shaft seal on '97 250 Mariner
I had the boat out yesterday for the first time this season. After getting back in the boat was hauled and put on a rack so I could put fresh bottom paint on today. When I walked up to the boat today there was a small oil trail running down the skeg. It appears to be coming from the just below the prop. I'm guessing the prop shaft seal is bad.
How do I go about changing the O-ring? Does the lower unit need to be dropped or can I get to it after simply removing the prop?
