- Apr 17, 2002
- 71,495
I just got done reading an article in Go Boating magazine,....
In it, Grid states that the new Alpha drives with the 2:1 lower unit gear ratio, When mated to the Upper unit for the 3.0l motor, that uses a 1.98:1 gear ratio...
The final yeild is a 4.16:1......
So,..... Somebody tell Me,.....
Have I been Wrong all these years in believing that the Combination of the Lower unit gear ratio,+ the Upper unit gear ratio have yeilded a Final Ratio of 1.98:1 for the 3.0ls....??..
Btw,......
Grid goes on to say that the Final Gear Ratios for the V6s is 3.90:1....
The 5.0ls are 3.47:1....
And the 5.7l ends up at 3.15:1......
Sooo,..... Before I wander over to Go Boating,......
Any Mathamagicians here able to tell me whether I've been Wrong all these years,....
Or,....
Is Grid Full of It Again,..??..??
I say Again, because a year or so ago, He tried to tell me that Thru-hull exhaust Causes rubber prop Hubs to Fail from a Lack of exhaust Heat.......
I called him out on it, but didn't argue the point.......
Thanks Guys,.........
Btw,......
Or,....
