  #1
Old April 9th, 2008, 02:37 PM
ehenry ehenry is offline
Default Late 80's Evinrude 48 hp fuel problem.....
I know I've seen this problem posted before but danged if i can find it.......this engine cranks fine. When you open the throttle it will reach 44-4500 rpms. After about 10 to 20 seconds the rpms drop back to 2800 to 3000 with throttle wide open. If you push the choke the rpms will go back up to 44-4500 for about 10 to 15 seconds and fall back again.
  #2
Old April 9th, 2008, 03:06 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Late 80's Evinrude 48 hp fuel problem.....
fuel restriction problem, either vent clogged or not open on tank. fuel pump weak, clogged high speed jets, stuck float needle valve. fueling, sucking air 99% dirty carb.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old April 9th, 2008, 07:03 PM
Silvertip Silvertip is offline
If you are using a portable plastic 6 gallon tank, empty it and check the inside for plastic debris. I've found many of these tanks with so much debris in them from the molding and drilling processes that it clogged the pickup tube in the tank. It happened to me on two separate tanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Late 80's Evinrude Rebuild abrown Johnson & Evinrude Outboards 3 June 28th, 2006 10:37 PM
Fuel Consumption: Late 80's 60hp 3cyl vs 90hp 4cyl NJCoastFlyFish Non-Repair Outboard Discussions 8 February 14th, 2006 05:46 AM
Evinrude 2 late 80's. Fuel Question evans91474 Johnson & Evinrude Outboards 1 September 10th, 2005 12:51 PM
Merc late 80's mod 200hp popit problem Fish on john Mercury & Mariner Outboards 0 July 29th, 2005 10:59 PM
Shift problem on a late 80's alpha mestey2004 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 April 26th, 2004 09:05 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
