  #1
Old April 9th, 2008, 01:51 PM
tim hagewood tim hagewood is offline
Question aluminum lund transom
I have a 1968 Lund that needs wood in trasom replaced. Any info will help thanks!!!
  #2
Old April 9th, 2008, 02:20 PM
rndn rndn is offline
Default Re: aluminum lund transom
Theres not a whole bunch of information. Take out the old one and cut a new one in the same size.
__________________
1996 Crestliner 2160 Phantom, 1996 Evinrude 130 HP
  #3
Old April 9th, 2008, 06:54 PM
5150abf's Avatar
5150abf 5150abf is offline
I used 2 pieces of 3/4 plywood glued together with Gorilla glue, it is waterproof.
I started with marine grade plywood but you aren't likely going to find that so go with exterior grade, once your peices are cut out and the glue is dry I would paint them with a basement waterproofer type product,Dri-lock is one kind I have seen do the front back and sides then bolt it in.
Thompsons is good for a deck on your house but I wouldn't use it on a transom board.
Use stainless hardware if at all possible and when you cut the boards start big and trim to fit.
Good luck
  #4
Old April 10th, 2008, 06:49 AM
JCF350's Avatar
JCF350 JCF350 is offline
Some ideas
http://forums.iboats.com/showthread....highlight=lund
Instead of going back with wood you could use Seacast.
http://transomrepair.com/zk/seacast.shtml
__________________
First "BIG" fish!!
  #5
Old April 10th, 2008, 07:55 AM
HONKER1 HONKER1 is offline
Send a message via AIM to HONKER1
When I replaced my transom I used 5150's method, with the exception I used non-corrosive screws to hold the 2 pieces together along with glue.
Also I took the extra time to waterproof the plywood with 2 coats of resin. I drilled all my holes before I painted on the resin.
Use your old transom board as a pattern, cut the new board a little larger and trim to fit.
  #6
Old April 10th, 2008, 10:20 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
Quote:
Ayuh,.......
Remove the Rotten Wood,......
Then,....
Replace it with New Wood,.......................
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #7
Old April 10th, 2008, 11:47 AM
Thumbs up Re: aluminum lund transom
Thanks for the info lots of help. If I go with the Seacast will it last longer an be stronger than just wood? Can you drill through the Seacast? What do you all think about using Gluvit for the inside the hull before redecking? Thanks again.
  #8
Old April 11th, 2008, 12:24 AM
JCF350's Avatar
Yes it will be way more gooder than wood
Be sure to follow the instructions letter by letter there is a manual on how to on the site also look at the FAQS listings.
Gluvit works. Good stay away from pressure treated woods around aluminum
GOOD LUCK!!!!!!
__________________
First "BIG" fish!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Removing middle rear bench? 79' 14ft aluminum Lund JosMN Boat Topics and Questions (not engine topics) 13 March 24th, 2008 12:27 PM
Pitted aluminum in transom Wishin I was Fishin Boat Restoration and Building 3 July 17th, 2007 12:33 AM
Replacing Floor in 1984 Lund 14" Aluminum taysburgh Boat Restoration and Building 2 June 12th, 2007 02:22 PM
Flexing aluminum on Lund ssv 14 scottrannie Boat Topics and Questions (not engine topics) 1 September 24th, 2003 09:31 AM
What do you think about Lund aluminum 14' boats? nhboater Boat Topics and Questions (not engine topics) 3 August 5th, 2002 02:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
