i have a question i hope someone can help with. first trip out last year motor ran fine. came home and changed plugs just for maint. second trip out i motor was running fine until one point at wot the alarm sounded constant.i did not notice any change in performance at all.when i backed out of the throttle the alarm quit.engine was not hot.again i tried full throttle and got the alarm.has to be fuel restiction right? well then i noticed at idle in gear going through no wake zone the motor was sneezing fierce and kept shutting off. while it was sneezing i hit the key to prime to see if motor cleared up but it sputtered worse. the primer bulb was soft at the time also. back home i looked everything over and notice there is no fuel filter that i could see.took off the air box to inspect carbs and pulled some of the drain screws on the bowls and got clean gas.i did notice at the bottom of the carbs there is a hose that looks to be coming out of the block with a screw in it looks like 3/8.is this part of the recirc system?compression is good 95 on all 6.i just need a new starting point if someone could help.the fact there seems to be no fuel filter scares me that something got into the carbs but why the alarm isnt the sensor for a restriction at the pump?
