  #1
Old April 9th, 2008, 12:28 AM
Fireson Fireson is offline
Default Loss of power on 96 evinrude 48
First time poster here, hopefully someone who knows more about motors then me can help. I recently took my boat out for the first time this year and i had some issues. The motor is not idling right at all. It is very rough and it ultimately dies if you don't throttle up. When i do give it gas, the motor seems to be at about half power when it should be at full power and speed. I did not have this problem last year. When i started looking at the motor, i noticed there was some gas leaking out from around a little part that was on the bottom of the fuel pump. It had a red plastic thing on it and it looked like a stem from a tire or something, maybe to bleed the fuel line. I really don't know. I do know that it is leaking from around there. So i guess my question is could all of my problems be caused by this leak? And if so, would i have to replace the entire fuel pump or just that little piece? Thanks so much in advance for your replies and advice!
  #2
Old April 9th, 2008, 07:21 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Loss of power on 96 evinrude 48
the item you are describing is the primer solenoid, it replace the choke butterfly in the carborator. when you press in the key in the on/start position, the primer allows fuel into the intake manifold, the enrich the fuel/air ratio. helping to start the motor. if it is leaking, 99% it is letting fuel into the intake also, flooding the motor at higher speeds, because the fuel pressure increases at higher revs. there is a rebuild kit for the primer, or replace it.
did you winterize your motor, use seafoam in your fuel, to keep the carb from gumming up. are you running new fuel.
here is a picture of a primer in the run position. also check hoses for cracks and leaks.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old April 9th, 2008, 07:29 AM
you probably only need part 6 gasket 341297 and part 13 O ring 331365, to see diagram, go here, look up 1995 48 ( diagram for 1996 is wrong) .
http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
FLORIDA GATORS
TEBOW Country
  #4
Old April 9th, 2008, 09:51 AM
Thank you for your advice. I am running new fuel but i did not use seafoam this winter(i should have). So i assume the primer solenoid could be the cause of all my problems, am i correct in saying that? Also i don't believe the impeller has been replaced on my motor, would it be a good idea to change it as well just as a precaution. Thanks for the help again!
  #5
Old April 9th, 2008, 11:42 AM
littletunny littletunny is offline
I have the same motor (91') and just got done doing a thorough cleaning of the carbs and it runs great so far but I still have to adjust the carbs.
Daddy,
The red lever on my fuel primer solenoid will spit a little fuel at start up, then stop. Is this normal??
  #6
Old April 9th, 2008, 11:52 AM
the primer solenoid should not leak at all. you carbs have an adjustment screws PRESET at the factory, do not mess with it. if you do there is a long process to reset it. that is what the OEM manual says.
Fireson, if your impeller has not been changed in 10 years, consider yourself very lucky. 2 to 3 years is recommended. although there was just posted, a guy is changing his for the 1st time in 29 years. if the solenoid does not solve your problem, then i would look at throughly cleaning the carbs, and rebuild kits. try the solenoid first, then we will discuss the carbs.
__________________
FLORIDA GATORS
TEBOW Country
  #7
Old April 9th, 2008, 01:37 PM
Just curious, how hard would it be to install another impeller. Can i do this myself if im careful? Also if i didn't treat the gas before winter, whats the chances my carbs are gummed up? Thanks again, Seth
  #8
Old April 9th, 2008, 03:23 PM
75% or more. the hardest part of changing the impeller is getting the shift linkage under the carb disconnected, and reconnected. the rest is just getting the 7 bolts that hold the lower unit, and 4 screws on the pump cover.
__________________
FLORIDA GATORS
TEBOW Country
  #9
Old April 9th, 2008, 03:53 PM
Well i guess i will deal with the solenoid first and then if i have to deal with the carb, i will get back to ya. Thanks for the help once again. Im going to go ahead and replace the impeller too. I just got the boat last year and im still learning about it. I dont know what i would have done if i didnt find these forums. Thanks again! Seth
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Evinrude 70 surge in power/loss of power huntingjustinlouise Johnson & Evinrude Outboards 6 April 8th, 2006 05:36 PM
Evinrude 90 hp loss of power, help please.... rsbbdut Johnson & Evinrude Outboards 1 August 4th, 2005 06:21 PM
loss of power in 59 Evinrude gmarshall43 Johnson & Evinrude Outboards 1 September 2nd, 2003 01:19 PM
87' 70H.P. EVINRUDE VRO LOSS OF POWER JoesBoats Johnson & Evinrude Outboards 0 July 28th, 2003 06:32 AM
'95 Evinrude 150 loss of power snowdust Johnson & Evinrude Outboards 8 August 2nd, 2002 07:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
