  #1
Old April 8th, 2008, 08:12 PM
sledstew sledstew is offline
Angry Evinrude 90 HP ignition problems "not solved"
I have a 1987 90 HP evinrude that is giving me problems ,here is the diagnosis. The motor is freshly rebuilt and compression is top notch , the motor starts fine but after about 30-45 seconds of running it will cough and sometimes its enough to kill the motor.It seems to me like some sort of ignition problem, here is what Ive done to troubleshoot the issue,
1) put new carb kits in it and tested VRO pump with new one = all is ok
2) tested and replaced timer base and flywheel= OK
3) tested and replaced stator=ok
4) The only thing I havent replaced is the powerpacks???
5) tested voltage regulator/rectifier= all is ok
6) checked all coil wires and coils= ok
7) All 4 cylinders have spark but it seems intermittent on both sides, a bit weaker on the starboard side
8) unhooked black yellow wire for kill switch =tested ok
Is it possible the guy who owned this before me burnt both powerpacks? It looks like he replaced the starboard pack .How do you test the packs with inexpensive tools, I have the DVA meter and a good multimeter.
Any help is greatly appreciated.
  #2
Old April 8th, 2008, 08:35 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: Evinrude 90 HP ignition problems
That cough is usually due to a slightly lean running carburetor.
Remove the carburetor face plate. With the engine running and with that coughing condition existing, stick two fingers into the carburetor throats, one carburetor throat at a time. You will be acting as a manual choke of sorts.
When (if) you find an offending carburetor, the rpms should increase slightly and the cough should cease to be. This would reveal an idle air bleed jet that has a slightly too large inside diameter.
Should the engine have a tendency to flood out with the fingers inserted, back the fingers out somewhat. Let us know what you find.
  #3
Old April 8th, 2008, 09:23 PM
HighTrim's Avatar
HighTrim HighTrim is offline
By all means follow Joes advice, but for your own knowledge for the future when checking the DVA output the orange wires from the power pack while connected to the ignition coils you should have a reading of at least 150V or more. If the reading is low on one cylinder, disconnect the orange wire from the ignition coil for that cylinder and reconnect it to a load resistor. Retest. If the reading is now good, the ignition coil is likely bad. A continued low reading indicates a bad power pack.
The following link is a DVA (Peak Voltage) and Resistance Chart for all your testing purposes.
http://cdielectronics.com/LinkClick....language=en-US
__________________
Chris
  #4
Old April 8th, 2008, 09:47 PM
I tried what Joe suggested and it didnt seem to help at all and it didnt seem to have hardly any affect on how it runs.Any other suggestions Joe???
  #5
Old April 9th, 2008, 10:23 AM
ezeke ezeke is offline
Default Re: Evinrude 90 HP ignition problems "not solved"
Check that the orange and blue wires from your powerpacks are running to the coils for cylinders 1 and 2.
  #6
Old April 9th, 2008, 12:00 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
Since the engine is fresh built, I myself would looking for a transfer port gasket, intake gasket, improperly sealed crankcase half or damaged lower crank seal. Any leak in these areas will cause a lean spit. Also check to see if flywheel keyway is sheared. (Install a stop or indicator in #1,bring to TDC and check pointer)
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Problems 1,2&3 solved, now problems 4 & 5 has popped up!!!!! bamafutbal Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 November 22nd, 2007 11:30 AM
I've solved some problems Tyme2fish Dockside Chat 3 June 3rd, 2006 06:21 AM
Hey Joe, my 200 evinrude has ignition problems po-it Johnson & Evinrude Outboards 4 September 21st, 2004 04:23 PM
Ignition Problem Solved???????? dstuard Non-Repair Outboard Discussions 5 April 4th, 2003 12:15 PM
Many problems solved with new Power-Pac sandy Johnson & Evinrude Outboards 2 October 4th, 2001 03:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
