Hello everyone.
I have just come into ownership of a 4cyl, mecury blueband 50hp with thunderbolt ignition. I have heard these are "bullet proof" motors but I have a problem.
Prop wont turn, cord won't pull. I have tried different gears but nothing happens. Prop is solid. As it won't turn in neutral, I am presuming the powerhead is not necessarily part of the problem but the gearbox might be.
Where shall I go from here? Shall I drop the lower unit? I have looked at it, and there are 2 visible nuts imbedded into the side under the flanges on the gearbox.
Only number I managed to get off the engine was on the side of the transom "1440-3255" any use?
I will post serial no. tomorrow as I can't find my torch and its dark! Shed lights are also broken! Thanks
