  #1
Old April 7th, 2008, 10:16 PM
Randy115 Randy115 is offline
Smile Compression on 1995 90HP Evinrude, one cylinder is 94 lbs.
Just got motor. Starts easily, sounds good, not been run on boat yet. Need an expert opinion. Three cylinders test at 108-109 lbs. Did test as recommended, engine warm at WOT. However, one cylinder tested at 94 lbs. The motor sat for about three months before I got it. Any suggestions? Should I take head off and look at cylinder? Could it be the head gasket? If rings are bad, should all 4 cylinders be re -ringed? If walls are scored, would it be ok to just fix that one cylinder only, if the others look ok? Thanks for any suggestions.
  #2
Old April 7th, 2008, 10:23 PM
Robj Robj is offline
Default Re: Compression on 1995 90HP Evinrude, one cylinder is 94 lbs.
Welcome to iboats!! The first thing I would do is run it a few times out on the water, not in your driveway. You said it is running good so that should not be an issue. Afterwards I would do a decarb and then retest. Those nos are not that bad, maybe just a little of carbon build-up. Do a search on decarb and you will get lots of info on how to do it. You can use a spray from Evinrude or buy Seafoam.
Have a great day,
Rob.
  #3
Old April 8th, 2008, 12:15 AM
Thanks for the info. I will do what you suggested. I am hoping that the number for that cylinder goes up.
  #4
Old August 27th, 2009, 07:17 PM
trolli trolli is offline
I just took my boat with 90 hp evinrude in for same issue. The mechanic told me that it is not really something to worry about yet. Can you let me know if your compression comes back after you run it for a while?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 Evinrude 130 V4 intermitent spark on one cylinder Luxury Johnson & Evinrude Outboards 4 May 29th, 2007 05:35 PM
1995 Evinrude 130hp will not start. No spark on 1 cylinder dtclements Johnson & Evinrude Outboards 14 February 7th, 2007 06:33 PM
1995 Evinrude 175hp Compression rkersh409 Johnson & Evinrude Outboards 0 August 27th, 2006 01:34 PM
1995 60hp evinrude compression ? mcw Johnson & Evinrude Outboards 3 July 19th, 2005 05:33 AM
#1 cylinder on 93'-90hp evinrude has no compression but the other three are OK fenceman Johnson & Evinrude Outboards 5 February 21st, 2003 06:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
