  #1
Old April 7th, 2008, 09:02 PM
pbuzz3323 pbuzz3323 is offline
Exclamation 2hp carb 1982 evinrude. e2rcne
cant find this carb anywhere...maybe just rebuild it? Both low and high speed needles are wobbly in the threads so its gotta be fixed. Just depends on threads on carb I guess.
  #2
Old April 7th, 2008, 09:31 PM
JB's Avatar
JB JB is online now
Default Re: 2hp carb 1982 evinrude. e2rcne
For a replacement used carb, try www.tcoutboard.com. It won't be cheap.
I would try a carb overhaul kit first.
__________________
RED SKY at night. . .
JB
  #3
Old April 7th, 2008, 09:46 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
There are fiber packing washers that are inserted in front of the brass jamming nuts to prevent any wobble or loosening of the needle valves (prevents turning due to vibration). Is it possible that those fiber washers are missing?
  #4
Old April 8th, 2008, 09:07 PM
Quote:
They arent missing but the black bushing was kinda shot on both high and low ...reordered all new stuff..even the needles. The low speed needle was even bent alittle but no damage to carb
  #5
Old April 8th, 2008, 10:58 PM
Joe Reeves's Avatar
Black bushing??
  #6
Old April 9th, 2008, 05:17 PM
Looked like a bushing,,maybe a washer...Its inside the small nut that the needle threads into. Checked on the breakdown and it lists it as Packing..2 in each needle, under the nut. Are those part of the carb rebuild kit that I got today? Got many small washers and such ...Never did this before but looks like I just take out old and put in new...after some cleaning I guess? After changing the packing how tight do I thread the nut on? The one the needle goes in? Is there an actual method to this madness?
  #7
Old April 9th, 2008, 11:23 PM
bump
  #8
Old April 10th, 2008, 12:20 AM
Joe Reeves's Avatar
The brass jam nut is tightened so that you can turn it to adjust it but too tight for it to move by itself (viberation etc).
Yes, the fiber packing washers come with the carburetor kit.
  #9
Old April 10th, 2008, 01:55 AM
Xcusme Xcusme is offline
One more thought:
Don't screw in the needle valve until it seats and then tighten the brass nut, it can cause the tip of the needle to jamb too hard into the seat. Back out the needle shaft well away from the seat, tighten the brass nut, then screw in the needle until it seats and back out to initial setting.
  #10
Old April 11th, 2008, 06:49 PM
OK...so seat the needle first or not? Im alittle confused on your answer......Never mind..got it...start the valve but dont seat it..Then tighten nut..
  #11
Old April 11th, 2008, 06:55 PM
Quote:
Or do i just start replacing things as they come off?
  #12
Old April 19th, 2008, 10:13 PM
Found my problem...Threads in the slow needle valve are messed up..Looks like former owner tried wrong needle and the proper one doesnt even come close to seating..I think Im screwed
  #13
Old April 20th, 2008, 10:21 PM
Problem solved...former owner had both needles reversed...fast in slow and vice versa....was able to tap out threads and fix problem...Like they say...Buyer Beware.
  #14
Old August 12th, 2008, 06:14 PM
andre Jacques andre Jacques is offline
HI try this place they keep everything for your outboard and the price are OK
I live in Canada (québec city and they ship everywhere)
Good luck , Bonne chance !
www.crowleymarine.com
EVINRUDE OUTBOARD 1982 (2HP)
For Models: E2RCNE
For exemple :
CARBURETOR
CRANKSHAFT & PISTON
CYLINDER & CRANKCASE
EXHAUST HOUSING
FUEL TANK
GEARCASE
INTAKE MANIFOLD
MAGNETO
MOTOR COVER - EVINRUDE
MOTOR COVER - JOHNSON
REWIND STARTER
  #15
Old August 12th, 2008, 07:25 PM
JB's Avatar
JB JB is online now
Did you notice that this thread is over 4 months old, Andre?
Any purpose to your post except, maybe, to promote Crowley?
That would be bad manners on a boat and parts retailer site.
__________________
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
carb model for 1982 v150 and carb rebuild question fishingdan Mercury & Mariner Outboards 3 August 14th, 2007 11:32 AM
1982, 115 Carb rebuild arrow62 Johnson & Evinrude Outboards 15 April 13th, 2007 08:07 PM
1982 198/898 merc carb/manifold tuffenuff Non-Repair Outboard Discussions 0 June 7th, 2006 04:48 PM
1982 140 mercruiser carb trouble Dandelion wine Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 October 11th, 2004 04:10 PM
Carb for Merc 4.5 1982-85 vintage agmec37 Mercury & Mariner Outboards 2 September 10th, 2003 01:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
