  #1
Old April 6th, 2008, 05:46 PM
patrick4266's Avatar
patrick4266 patrick4266 is online now
Send a message via Yahoo to patrick4266
Default 1961 evinrude 40 hp ignition wire
I got this engine with the controls but no key. I want to see if it will get fire. Does any one know which wire is the ignition wire?
__________________
1972-85 hp-rude
1970-85 hp-rude
1988 yamaha pro50
  #2
Old April 6th, 2008, 08:50 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1961 evinrude 40 hp ignition wire
unplug the harness, and jump the solenoid.. there should be a number next to the key slot, that is a code for the key, dealer can get them. ishopmarine has them also.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old April 6th, 2008, 10:48 PM
BoatBuoy BoatBuoy is offline
Here's the wiring diagram for your motor (w/o generator)
Edit: Drawing courtesy Garry Spencer
  #4
Old April 7th, 2008, 12:34 PM
thanks guys
__________________
1972-85 hp-rude
1970-85 hp-rude
1988 yamaha pro50
  #5
Old April 7th, 2008, 03:52 PM
F_R F_R is offline
Note that there is no "ignition wire". The two black wires are shorted together by the key switch to STOP the motor. Using a wrong switch that feeds voltage to the ignition will melt the coils.
  #6
Old April 7th, 2008, 09:32 PM
So how do i Jump it with out the key? I know how to get fire to the selonoid but how do I to the ignition?
__________________
1972-85 hp-rude
1970-85 hp-rude
1988 yamaha pro50
  #7
Old April 7th, 2008, 09:59 PM
HighTrim's Avatar
HighTrim HighTrim is offline
Did you look for the key code patrick?
__________________
Chris
  #8
Old April 7th, 2008, 10:01 PM
F_R F_R is offline
The ignition is magneto. Self powered, like a lawnmower. It doesn't need to be connected to anything in order to run. In fact, you can disconnect everything and hand crank it and it will run. The key switch only turns it off.
  #9
Old April 8th, 2008, 08:06 AM
larky's Avatar
larky larky is offline
just make sure that the two black wires, mentioned above, are not connected. remove them from the switch and hook a toggle switch between them for now.
  #10
Old April 8th, 2008, 11:06 AM
No I did not get the key code yet. I wanted to see if it was getting fire before I invested too much time are money in it. It looks like it has been sitting for many a years. However after putting oil down the plug holes and spinning it a bit I am getting around 90 on the compression so, I figure if it gets fire it will start. I am going to do that toggle ignition thing. Being new to out boards I did not realize that is how magnetos worked. Thanks a lot.
__________________
1972-85 hp-rude
1970-85 hp-rude
1988 yamaha pro50
  #11
Old April 8th, 2008, 03:09 PM
F_R F_R is offline
You only need the toggle to shut it off. Forget that for now. You can shut it off my just touching the two black wires together if you have to. As you suggest, the first priority is will it even run? THEN you can worry about stopping it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
ignition resistor wire for Evinrude 60HP Zeph Electrics, Electronics and Trolling Motors 3 March 22nd, 2008 10:49 PM
1961 johnson 40 hp ignition wiring steve1960 Johnson & Evinrude Outboards 5 May 17th, 2007 08:18 AM
1961 spark plug wire terminal tool bingopajamas Johnson & Evinrude Outboards 4 May 26th, 2006 10:48 AM
Mercury Gauge Wire/Ignition Wire Colors Mike D Cincy Mercury & Mariner Outboards 2 August 5th, 2004 02:53 PM
68 evinrude 40hp how to wire six post ignition switch mirobb Johnson & Evinrude Outboards 2 June 15th, 2004 10:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
