I had a mechanic check out my motor and he said that because the motor wasn't pumping much water that i has accidently overheated the motor and i needed to replace the head gasket. He replaced it and the impeller and when i picked it up it sounded great in the tanks. I bring it home and the next day i take it out to test it in the water, it started and idled great but once under way it was acting funny. At half throttle it would be very slow to raise in rpm( i would turn throttle but it would take at least 5 sec to get to the proper rpm). Max speed i got was 12 mph, before he fixed anything it would max out at 19 mph. Know at full throttle it will run for a while but then all of the sudden it will make a noise almost like it's hitting a rev limiter. It runs but not at all how i think it should. What could be wrong? Is it related to the head gasket, am running on one cyl., is it something unrelated? What do you guys think? I swear i have the worst luck with outboards.
thanks
thanks
