Waters Edge
- Feb 20, 2008
- 1
I have a 2002 Crest pontoon with a 50 HP Mercury outboard motor; model 50ELPTO. Can you advise me on solving a problem when the motor "breaks loose" or looses traction from time to time. The most frequent occurrence of this problem is when I have the extra weight of 6-7 passengers and I try to raise the speed of the pontoon. It will also happen when raising the trim or I turn sharply to either side. The transom bracket is at the lowest setting. The prop is a U6-512. I would sure welcome your advice on this matter. First time user...hope I'm doing this right!
