  #1
Old April 4th, 2008, 10:58 AM
2fs2ns 2fs2ns is offline
Default Best Prop for Mercury 35hp on 20' Pontoon
Yes it's underpowered...that's in the budget...
Until then though, I need to either get my current prop repaired (little boogered), or get a new one.
New boat to me, I don't know WOT for this engine.
Any suggestions from someone with this same setup? '89 Mercury 35, 20' Bass Buggy.
Thanks guys!
  #2
Old April 4th, 2008, 11:01 AM
Silvertip Silvertip is offline
Default Re: Best Prop for Mercury 35hp on 20' Pontoon
If the original prop performed ok for you get it repaired or buy an exact replacement. The numbers are on the barrel or hub of the prop. Without a tach reading at wide open throttle we can't tell you what's best. Merc makes a series of four blade pontoon props so check with them but you still need to know current WOT RPM with the current prop to pick the right pitch.
  #3
Old April 4th, 2008, 04:44 PM
What's the best way for a WOT reading? Put it on muffs and throttle up?
  #4
Old April 4th, 2008, 04:52 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
You must run the boat on the water with a normal load and record the highest RPM's. Throttle it up on the muffs and you'll be getting a new engine sooner than you'd like. 5500 RPMs would be the number to shoot for..
__________________
Rick
"Boating is Life...All the rest is just Details"
  #5
Old April 4th, 2008, 04:58 PM
Hehe, good to know! I'm gonna get it out on the water today/tomorrow for the first time...we'll see how it goes.
  #6
Old April 4th, 2008, 05:20 PM
So you haven't run the boat yet and have already determined it's under powered! you might be surprised. Pontoons don't go very fast regardless how much power you have. The object is to prop the engine correctly to run at its maximum recommended wide open throttle rpm with an average load. Whatever speed you get is what you get when you have the right prop. Just so you know -- you NEVER - EVER run an engine wide open on muffs. You might be very surprised to learn that you might not be able to shut it off. It's called run-away and it will rev until all of the internal parts try to get out of the engine which obviously makes a big mess. And you can ignore all of the advice here unless you actually have a tach. Without one you don't know how fast the engine is reving.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
MERCURY 35hp PROP bowlin257 Prop Questions and Topics 3 June 23rd, 2008 06:31 PM
Prop for 25' pontoon elake Prop Questions and Topics 1 June 19th, 2007 04:38 PM
Pontoon Prop Help Please R H Cotton Prop Questions and Topics 12 April 22nd, 2007 06:35 PM
Prop for pontoon rickdb1boat Prop Questions and Topics 3 March 11th, 2006 03:58 PM
Mercury 35hp, 13-3" Boaton Whaler - ?prop size? gbarden Mercury & Mariner Outboards 1 September 8th, 2002 08:01 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
