  #1
Old April 3rd, 2008, 01:08 PM
fingershooters fingershooters is offline
Default Mercury outboard bottom cylinder wet.
I have a 1972 mercury 80 hp outboard. I rebuilt it last year by replacing all the piston and rings. I tried to change the head gasket and exhaust gaskets but the bolts were badly oxidated. I broke one bolt on the exhaust side. Now the botton cylinder is wet all the time. Dont think its fuel because I swopped the carbs. Do i need to replace the exhaust gasket. If so what would be the best way to get the bolts out. Heat might ruin the head. Tried PB baster but didnt help.
  #2
Old April 3rd, 2008, 02:46 PM
Chris1956 Chris1956 is offline
Red face Re: Mercury outboard bottom cylinder wet.
The cylinder head on that motor is non-removeable. What appears to be the head bolts is actually a water jacket cover over the head.
Water will enter the bottom cylinder via the lower crankcase seal, the inner exhaust cover, or the exhaust baffle. You will need to pull the powerhead to replace the crankcase seals (install 3 seals vs the two it came with). It is a lot easier to pull the powerhead to get the the exhaust water jacket
  #3
Old April 3rd, 2008, 03:29 PM
Default Re: Mercury outboard bottom cylinder wet.
Thanks. Whats the best way to get oxidated bolts out of the exhaust cover. I got most of them out but 4 wont budge. I broke 1. Afraid to heatup might riun aluminum block. Any other suggestions. The bolts that came out were full of white powder.
  #4
Old April 3rd, 2008, 06:19 PM
*EdC*'s Avatar
*EdC* *EdC* is offline
There is no "good" way to remove broken bolts.......Some of the methods I use are.
1. Lots of PB Blaster everyday for a week
2. Center punch, and drill it out
3. A Dremel with an end mill type bit.
4. heat, of course
5. Air impact.. carefully
6. Easy-outs
Here is a link that might help you out
http://www.truebite.com/remove/
Good luck,
Ed
  #5
Old May 10th, 2008, 04:50 PM
Default 1988 johnson 88 spl compression
I check out a 1988 johnson 88 spl compression and found each cylinder is 90Lbs.
what should they be?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 mercury outboard 6 cylinder, 90hp....hard to start, doesnt idle in gear Edison Mercury & Mariner Outboards 10 November 1st, 2007 09:04 PM
Gas problem on 1981 40 HP 2 Cylinder Mercury Outboard jathomps04 Mercury & Mariner Outboards 2 March 10th, 2006 05:57 AM
1984 90 HP, 6 Cylinder Mercury outboard copley Mercury & Mariner Outboards 3 July 24th, 2005 05:20 PM
Bottom cylinder not firing ra_wii Force & Chrysler Outboards 5 August 15th, 2003 06:16 AM
No compression in bottom cylinder 91Force90hp Non-Repair Outboard Discussions 4 July 15th, 2002 02:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
