  #1
Old April 3rd, 2008, 10:42 AM
mikeneal mikeneal is offline
Default Wiring Wiring thru hull for center console, any tips
I didn't know where to post this, and note to moderators, please move if in wrong place. Anyhow, I recently purchased a little 17' CC to fish with and I am adding a depth sounder. The rigging tube does not have a rope, or any wiring thru it, just throttle cable, shifter and steering. The PVC tube in the rear of the boat and in the console just dumps into the hull. Any great ideas how I can run the wiring to the center console? I tried for a while with fish tapes etc. with no luck. I suppose I could remove a throttle or shift cable and use that but thought I would ask for suggestions. Thanks.
  #2
Old April 3rd, 2008, 11:51 AM
fishmen111's Avatar
fishmen111 fishmen111 is offline
Default Re: Wiring Wiring thru hull for center console, any tips
Just went through that mess myself. I ended up using a 3/8" wide snake (smallest) with the end removed. Taper tape small poly rope to the end and then take your time. When through, taper tape wire to rope (don't forget another pull line for the future), and pull back through. The whole time, I had to jiggle the steering and control cables. Try from both ends (console and stern). If after many attempts, you do not succeed, I would look for any wire not in the main harness, cut it and use as a pull line. Of course once again, you need to attach a pull line to bring it back to re-attach. No joke, this could take MANY attempts.
  #3
Old April 3rd, 2008, 09:30 PM
eastern27 eastern27 is offline
Quote:
You may have a setup where the pvc dosn't run the whole length of the boat. That would explain not being able to get a fish tape through. You might be running into foam. Myself I'd get a small plastic ball, attach it to some fine diameter fishing line and suck it from one end to the other with a shop vac. Once you have a lead in there you can pull stronger stuff to pull your cable.
  #4
Old April 4th, 2008, 04:28 PM
The PVC does not extend all the way thru the hull, I can tell from the fish tape the opening just enters the bilge.
  #5
Old April 4th, 2008, 06:06 PM
JB's Avatar
JB JB is offline
Well, in that case I would use one of the control cables to pull a double line through, then use one of the lines to return the control cable, like your last thought.
__________________
RED SKY at night. . .
JB
  #6
Old April 5th, 2008, 12:07 PM
I was just about ready to pull the throttle cable off and use that when I had an idea. I had a pretty stiff steel fish tape I threaded into blige and used a large very strong Neo magnet I had laying around. I tied a piece of 50lb test fishign line to the magnet and threw it repeatedly thru a access hole I drilled under the center console. (I am going to put a 6" deck plate there today). I got super lucky and stuck it to the steel fish. My next door neighbor heard my throwing the magnet up inside the hull and walked over. I had to endure several "fishing" jokes , but was all worth it when I felt it drag the fish tape to my new access port.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
MitchCraft Boat 17ft center console with a deep v hull? TheCoralReefer Boat Topics and Questions (not engine topics) 5 July 28th, 2008 01:39 PM
Battery Set-Up/Wiring for19foot center console 727hog Electrics, Electronics and Trolling Motors 13 November 19th, 2007 08:56 PM
console wiring question rbigg Electrics, Electronics and Trolling Motors 2 February 19th, 2006 04:51 AM
Re-wiring Center Console - ignition harness - tilt harness Kesh Boat Topics and Questions (not engine topics) 2 May 22nd, 2004 03:41 PM
What do you think about converting a 15' Tri-hull walk thru to a center console? Capt. Bob Boat Topics and Questions (not engine topics) 1 April 16th, 2002 02:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
