  #1
Old April 2nd, 2008, 10:44 PM
j_seph j_seph is offline
Default Carburetor on 1997 evinrude 50hp
I used this stuff from quicksilver that is supposed to clean out the carbon build up. Well after following the directions on the can I noticed that when spraying it into the upper carb it would not choke the engine down as it would when spraying into the bottom carb. Is this a firing/ignition problem or a carb problem?
Thanks
Joe
  #2
Old April 3rd, 2008, 09:49 PM
Default Re: Carburetor on 1997 evinrude 50hp
Anyone?
  #3
Old April 3rd, 2008, 09:55 PM
HighTrim's Avatar
HighTrim HighTrim is offline
I am personally unfamiliar with that product, but in general, you may have issues with your carb. What is the condition of the plugs? Is the motor running poorly or giving you any issues?
To test the ignition/spark use an inductive timing light or an inline spark tester with the gap set to 7/16 of an inch. The spark should jump the gap with a bright blue ZAP!!
Seafoam is a tried and true product to use during the decarb procedure. Check the FAQ for instructions.
__________________
Chris
  #4
Old April 3rd, 2008, 10:08 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
the quicksilver product is very similar. i would say that you did not have spark on the top cylinder.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old April 4th, 2008, 08:46 PM
It runs out fine, it idles fine for a while. Then it gets to where when it is idling its sort of like it stops running for a split second and kind of like a cough. Had a new power pack put on recently(6 months)
  #6
Old April 5th, 2008, 10:55 PM
Spark was pretty 1/2" or better on both cylinders, so sounds like I will be running seafoam tommorrow
  #7
Old April 6th, 2008, 06:47 AM
i think you are running lean on one carb, probably the top. low speed jet need to be cleaned out. you can get them out without removing the carbs. i take a couple of strands of wire out of an extention cord. and clean out the jets. then blow them out. you need special tool 317002 to get them out. or make one.
__________________
FLORIDA GATORS
TEBOW Country
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 Evinrude 50hp 2stroke.misses boatingfromthepoorhouse Johnson & Evinrude Outboards 0 April 25th, 2007 09:46 PM
1997 Evinrude 50hp still having problems j_seph Johnson & Evinrude Outboards 9 April 7th, 2007 08:12 PM
2003 mercury 50hp carburetor adjustments mark cale Mercury & Mariner Outboards 1 January 31st, 2006 05:18 PM
50HP Johnson Carburetor overhaul yoda Johnson & Evinrude Outboards 5 January 21st, 2004 06:44 AM
Evinrude 1973, 50hp, Lark, Carburetor Linkage tonyunited Johnson & Evinrude Outboards 4 June 13th, 2002 06:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
