Johnson model J75TRLCSA I am rebuilding motor and the original temp sensor is a bit rusted from blown head gasket and while it is apart I want to replace it. The BRP website shows 386686 as part # but the original only has 1 brown wire coming out and I saw one on Ebay that says it is 386686 but has 2 wires coming out "http://cgi.ebay.com/ebaymotors/NEW-OMC-JOHNSON-EVINRUDE-TEMPATURE-SWITCH-386686_W0QQcmdZViewItemQQcategoryZ26455QQihZ024QQitemZ370023270062QQrdZ1QQsspagenameZWDVW" . If it is , what do I do with the other wire?
Here is what I have done so far:
Bored .020 over and checked for warpage of head
new pistons, rings, all bearings, rebuilt carbs, new water pump complete, all new coils
During tear down found water had gotten to rod and crank bearings so I picked up another powerhead cheap and used crank and 1 rod from that.
Thanks,
Chris
Thanks,
Chris
