Ok, we bought this motor about 2 months ago, everything "working", took it into the shop, to get it checked out and tuned up, and after they adjusted the points and carb or whatnot, they found out that one of the cylinders wasnt firing, and for some reason after they fixed this, the water pump blew up... well i replaced the impeller and still no water flow.
i have seen youtube videos of this motor run, and i am sure that i got the impeller installed correctly
anyways, the next thing that i thought it could be was the thermostat, so after a little searching, i found out where it was and i went about removing the cover. the cover doesnt look like it has been removed... ever.
well i broke the edges of the thermostat cover (i pryed from the inside edges, not the screw holes).
so this is about where im at. i looked all over iboats store for the cap (which i still havent been able to remove) and i need the correct seals and springs and whatnot.
the part number 18-3674 doesnt look like it has the cap, and what i need, i could be wrong
keep in mind that i am a newbie to this type of stuff, im good with my hands, i build computers and such, but im not up to speed on the vocabulary and parts this motor requires.
thanks for all the help
Jgweb2000
Jgweb2000
