ok heres what I got a 74 70ho evinrude with a bad lower unit,it apears the thrust washer on the drive shaft let go and knocked a whole through the worm gear case. then the fragments got into the hydraulic pump and did a number on that.
so what I would like to know is where to get another lower unit? or maybe just the pump I have a welder freind that thinks he can fill the hole in the case.
what other years fit this power head? can I put another lower unit on it that does not have this kind of setup?
thanks guys.
thanks guys.
