Re: 120 Twin Force Engines
I think what the person ment was if the motors were set up for opposite rotation. One rotates to the right, one rotates to the left. This is usually the case if they came off the same boat. Check and see if the props are the same.
Counter-Rotation
Steering can be a real chore with a dual engine power setup. When the props turn in the same direction, the boat tends to list and steer off course. Keeping an even keel and true course requires constant attention, especially in choppy water and high winds. Much of that problem can be solved by having two props turn in opposite directions. In other words, counter-rotation. The major advantage of counter-rotation is its ability to enhance performance by reducing steering effort in all RPM ranges.
Most single engine boat setups normally operate in forward motion using clockwise rotation of the engine and gearcase. Although counterclockwise rotation setups have been used since the creation of the outboard engine, the use of counter- rotation has become more prevalent in the last decade. This increase is largely due to the manufacturing increase of larger twin engine recreational boats and performance boats.
To better understand how counter-rotation enhances performance, you must first understand what happens under normal conditions using clockwise rotation propellers. Clockwise rotation propellers, when turned in the same direction, will tend to list or walk to the right side of the direction they are moving forward in.
Left-handed or counterclockwise rotation is usually accomplished by using a special gearcase configuration that rotates opposite of engine rotation under normal operation. Counter-rotation is mechanically achieved by driving the gear clutched to the propshaft in counterclockwise rotation when shifted into forward gear. A counter-rotation gearcase is completely different than a standard gearcase, as it is comprised of special parts that provide strength and durability to accomplish this reversed rotation.
