Re: New X7 prop from Mercury; Fury
I was supposed to get one in a 24P sometime this winter....haven't seen it yet.
I can tell you it's a hybrid between a Tempest and a Laser with the X7 alloy.
The only problem I have with these Merc props is the hub...the flo-torq does not work well on my 'Rude. They had some flo-torq iv's that are rubber insted of plastic but built for Merc-length splines only and I never got the chance to ream one to fit. Solas has a rubber insert to fit all of these that use this type hub, and it's the best I've found yet, but after snugging one down, you almost ruin the hub removing it to install in another prop.
