Re: grey oil
Sorry, but Ill have to disagree.
The white drain and gear washers are "crush" washers, and should only be used once. They do not have the same effect the second, third time around. The drain and vent screw holes are the number 1 spot for water intrusion, in many cases, and I would not jeopardize that for the pennies that the washers are worth. I buy them by the bag.
That is just my own humble opinion though. Could be wrong (wouldnt be the first time
I find these oil pumps a bit handier and cleaner than the tubes of oil. They come with an adaptor to screw into the drain screw, allowing minimal mess and waste.
