I have a mercury XR4 which shows very little water pressure. 0-2 psi at idle and maybe 6-8 PSI at WOT. I've installed a new water pump (complete) replaced the thermostats, replace the poppet valve (complete) and still get exactly the same results.
When I'm running in warm water the temp gauge goes way up, especially if I'm running at less than about 1/3 throttle. Last summer the buzzer went off a couple times when I was running slow in rough water and I had to shut it down to cool. In the cooler winter water (50-70 deg.) it doesn't get quite as hot.
One time last summer I revved it up hard in neutral and the pressure jumped up to 8-10psi at idle and 18+ at WOT. This only lasted for one day and it went back to the same thing it always does the next time I put it in the water.
I've checked all the rubber water tubes which appear to be clear. I can take out the thermostats and I get a good flow through both sides and to the pee hole, but just not much pressure. I even took off the tube at the top of the block (that feeds the pressure gauge and the poppet) I put on a piece of spare tubing just to see the flow, and it seems to again flow well, but just has very little pressure (at idle).
This motor has had the lower unit replaced with the larger diameter version. My theory is the water pump is not sealing properly to the water tube. Perhaps due to a mis-matched lower unit (shouldn't all Mercury V-6 L/U be interchangeable?) Anyone have any thoughts on this? Is it possible to somehow put in an extra seal under the water tube to make sure this is mating up properly?
Also - I believe I used Sierra kit #18-3319. Is there a possibility this isn't the correct kit for this particular lower unit? If so, is there any way to identify the lower unit and know which pump I need to use to make this work properly? Sierra also makes pump models #18-3314 and #18-3319 for the Mercury 150. Could one of these actually be the correct model for this lower unit/powerhead combination?
I see lots of other XR4 owners with a similar issue - Is it possible this is happening anytime a replacement L/U is put on an XR4?
Thanks for any help.
Duke
Smyrna, TN
Duke
Smyrna, TN
