Re: Rented harmonic puller but
I used to be an assistant manager for the world's largest automotive aftermarket retailer AUTOZONE.
I would not reccomend using the bolts supplied with the puller, go to the local hardware store and purchase grade#8 bolts, that way you know you have good new bolts and threads for your project.
I believe and do not quote me as this is from memory that you need to mark the bolts at 7/16" depth and thread them that deep then go ahead and remove the flywheel, you need to be careful as when the flywheel does pop off it has a tendacy to really POP off, also do not lose the key that is under the flywheel.
Make sure when you re-install the flywheel it is dry, no lubricant and torque to what your manual says torque specs are.
PLease double check the depth of the bolt into the flywheel I believe it is 7/16", still on the first cup of coffee here at the office.
