  #1
Old March 31st, 2008, 03:05 PM
martysauer martysauer is offline
Default '78 evinrude 35hp not starting
I thought that I needed a new prop because the boat would under load all of a sudden rev real high, yet slow down - so I replaced prop, and then it happened again, and I was thinking that I was slipping out of gear somehow. But as I was diagnosing the issue (while on the lake), eventually the engine started squealing (from the flywheel), and almost making a grinding noise and eventually wouldn't start back up. The flywheel almost feels hard to move at some points, and then it will seem to move freely, but I'm not hearing any pop from the valves (while the plugs are out) - in other words, at some points there seems to be no compression and then full compression. Could the issue be a woodruff key? If so, why the squealing (if you have a guess)?
Thanks,
Marty
  #2
Old March 31st, 2008, 05:00 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: '78 evinrude 35hp not starting
drop the lower unit then turn the flywheel. if the head turns easily, the lower unit is shot, rebuild. there would be no compression with the plugs out, and the motor has reed valves, not moving valves like a 4 stroke motor.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old April 1st, 2008, 09:33 AM
I understand how to check for compression, I just didn't write it clearly. What I'm saying is that it seems to vary between hearing the pop sound like it might actually be starting to then hearing nothing, which is why I was wondering if anyone has experienced anything like that with a sheared woodruff. I'd rather not pull the flywheel if it's definitely not the woodruff key.
  #4
Old April 2nd, 2008, 04:13 PM
Anyone else have any ideas about this one? I am probably going to pull the flywheel this weekend, but I want to make sure I'm not chasing a red herring.
  #5
Old April 2nd, 2008, 04:34 PM
samo_ott's Avatar
samo_ott samo_ott is offline
Any chance it was overheating?
__________________
Steve.
  #6
Old April 2nd, 2008, 04:35 PM
pulling the flywheel is not bad.
__________________
FLORIDA GATORS
TEBOW Country
  #7
Old April 5th, 2008, 05:37 PM
bump
  #8
Old April 13th, 2008, 09:43 AM
Smile Re: '78 evinrude 35hp not starting
A big thank you to everyone who helped. I was able to get a local service station to use their air wrench on the flywheel nut, and the flywheel just popped right off, I put in the new flywheel key, and it started right up, I took it out on the lake yesterday and it ran like new!!! Couldn't have done it without the help I got here!!!
  #9
Old April 13th, 2008, 11:15 AM
67Johnson6HP 67Johnson6HP is offline
Hope you torqued that flywheel nut!
  #10
Old April 13th, 2008, 12:48 PM
BoatBuoy BoatBuoy is offline
To expand, if the key sheared, something caused it. Most likely the flywheel was not properly torqued to start with. I don't know about your '78 but the manual for my '77 specifies 100-105 ft/lb of torque. Your's is probably the same.
  #11
Old April 13th, 2008, 01:05 PM
Mine is the same. I tried to get the nut as tight as I could, but it's kind of a tough thing, because what are you supposed to hold while you tighten? I used a soft piece of 1x jammed in between the cavitation plate and the prop, is there something else people do? I was able to tighten it quite a bit, although I didn't use a torque wrench, so I can't give you a measurement.
As far as what made it shear in the first place, I honestly think that the engine is 30 years old, and things break - am I wrong?
  #12
Old April 13th, 2008, 01:10 PM
samo_ott's Avatar
The key should not just break on it's own. Even with age. Was the old key sheared off? Was it there at all?
They have flywheel straps to hold it when you tighten it. You need 2 people though.
If the flywheel popped right off on it's own when you took the nut off it really was bust and loose.
__________________
Steve.
  #13
Old April 13th, 2008, 01:21 PM
Yes, it was sheared, I had to punch out the two halves from the cranshaft and the flywheel itself. I tried holding with a strap wrench(with help from a very strong person) and believe me, it wasn't happening. The manual says to use a flywheel holder for my particular motor (which I obviously didn't/don't have), and the strap wrench for smaller motors. I suppose I could put some locktite on top, but honestly the flywheel just doesn't seem to take much of a load to me, so it seems overkill to do that.
  #14
Old April 13th, 2008, 06:25 PM
Yep, in this case. The keys don't weaken with age. That flywheel was put on without proper torque. Sounds like you did the same and the chances are very good the same thing will happen.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 35hp Evinrude rough starting DDAVIS89325iS Johnson & Evinrude Outboards 1 September 11th, 2007 05:55 PM
STRANGE starting problem 78 35hp evinrude jkarr Johnson & Evinrude Outboards 8 December 19th, 2006 09:59 AM
'73 Chrysler 35hp not starting scottbram Force & Chrysler Outboards 7 August 13th, 2006 11:00 AM
Chrysler 35hp Starting problems Ontheweekend Force & Chrysler Outboards 6 February 9th, 2006 06:57 PM
35hp mercury starting problem griff68 Mercury & Mariner Outboards 3 May 26th, 2002 06:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
