  #1
Old March 31st, 2008, 12:41 PM
Fester's Avatar
Fester Fester is offline
Exclamation Evinrude Sportwin Fuel Leak
I have a 1947 Evinrude Sportwin 3.3hp motor that has a leak on a small copper pipe on the right side of the motor (not the main fuel line) that looks like it feeds into the primer portion of the motor. If the motor is upright it does not leak but if I tilt it so that it is out of the water it leaks pretty bad. I checked it and it seems that there is a 1 inch pirce of hose that is dryrotted that is connecting the 2 pieces of copper together. The motor is pretty old and I know that replacing the small piece of hose will probably fix it but I do not know much about motors and wanted to make sure that this is common. I just purchased the motor on E-Bay and he advised me that it was in "Excellent working condition" but it has it's problems. I did have a chance to start it and it cranked up 1st pull and that was a great sign but it seems that it wants to idle very high and when I try to take the idle down it cuts out. The rich / lean dial on the front turns but is not attached to anything (is this normal?) Sorry for all of the questions, this is my 1st motor and I want to make sure that it is in good enough condition that I only have to put a little into it initially to get it running well. If so, I plan on restoring it. Any input would be appreciated.
  #2
Old March 31st, 2008, 02:02 PM
tmcalavy tmcalavy is offline
Default Re: Evinrude Sportwin Fuel Leak
Replace the copper line with another, or mate in a rubber hose instead. The rich/lean knob should be attached to a high or low-speed needle that adjusts by turning clockwise or counterclockwise. You sure there's nothing attached to the knob? Photos would help. Have you checked compression, tank/fuel line/carb cleanliness, spark, lower unit lube? Those are nice little motors, very simple and reliable. You can get old Evinrude service manuals at www.acmeoutboards.com. Post back and let us know how it goes.
  #3
Old March 31st, 2008, 02:19 PM
Fester's Avatar
There is something attached behind the knob and it has a small thin metal bar attached to it with a obling hole at the end but that is attached to nothing. I will post pics later today to see if I can get more info from that. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Sportwin 3.3hp 4423 pull cord and gas leak cassfam7 Johnson & Evinrude Outboards 2 October 12th, 2009 05:33 PM
Help! Carburetor Fuel Leak - 1989 60HP 2 Carb, 3 Cylinder fuel leak from Jet wgstelz Mercury & Mariner Outboards 1 September 23rd, 2006 07:51 PM
1958 Sportwin has small leak from crank/head? mologus Johnson & Evinrude Outboards 4 August 3rd, 2005 04:17 PM
1941 Evinrude 3.3hp Sportwin fuel mix? Squeakit Johnson & Evinrude Outboards 2 October 16th, 2003 01:54 PM
9.5 Evinrude Sportwin Model Year and Fuel Mixture Mallardman Johnson & Evinrude Outboards 4 August 7th, 2002 10:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
