OK, I've been around here a while and have read many fiberglass repair threads. I have a job I need to do (or have done) on my 1985 19' mark Twain. It's not a showpiece boat but not in bad condition either. However, there was this little collision between the bow and the dock......well you get the picture. Anyways I'm wondering just how bad/good i can expect the results to be and if I am thinking through the repair correctly. here's the plan.
Basically, i have a maybe 8 inch section right on the center line (tip) maybe 2 ft from the rail. it's just below the U-Ring for pulling onto the trailer. The deepest part is maybe 1/8 into the glass, not quite all the way through.
So, i figured I'd rough sand it. Clean with mineral spirits or whatever. Then layer some glass (do I use epoxy resin or poly ??? as maybe the current glass used poly - but I have no idea). So, maybe a few layers cut to the general shape of the gouge, smaller at first to fill the deeper wound. Then one last layer that overlaps the "good" glass edges.
Sand it all down then try as best I can to match the gelcoat. It's an off-white color which may help a bit I'd guess. I've never gelcoated, but will ask detail questions later on.
Anyone care to guess how well this can be done or how awful it will look? Again, not a showpiece boat but I have my pride..... All advise is welcome!
