  #1
Old March 30th, 2008, 09:25 PM
Seascout3 Seascout3 is offline
Default 1994 200hp Mariner lower unit help
I am trying to remove the lower unit gearcase to replace the water pump. I have had it off before about 2-3 years ago for a water pump so I am familiar with the procedure. I have all nuts and bolts off.(yes, even the one under the zinc tab). When I put it together I antisiezed all bolts. All the hardware came off easily. I still can't get the lower unit off. The forward top stud seems to have corrosion around it. I put the nut back on and hit it pretty good and it didn't budge. I put some CRC 656 on it and will try again tommorrow. And suggestions would be appreciated. I don't have a torch to apply heat, I do have a propane torch but I don't think it would get hot enough.
Thanks
ED
  #2
Old March 30th, 2008, 10:18 PM
rwunstel's Avatar
rwunstel rwunstel is offline
Send a message via Yahoo to rwunstel
Default Re: 1994 200hp Mariner lower unit help
Just double check and make sure all (7) connecting points are free. (1) in front, (4) on the sides, (2) in the rear. I've forgotten the one in front of the trim tab.
  #3
Old March 30th, 2008, 10:37 PM
j_martin j_martin is offline
The propane torch is worth trying. Aluminum expands pretty fast in the heat, and the heat helps the penetrant until it boils it.
Did you lube the driveshaft when you put it on. Might be seized up inthe crankshaft.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1993 200hp lower unit (do it yourself?) snyder Mercury & Mariner Outboards 4 July 12th, 2007 02:56 PM
200hp Mariner w/ lower unit problem Gerome Finley Mercury & Mariner Outboards 6 March 2nd, 2006 03:06 PM
Lower Unit 95-200HP sunpacman Yamaha & Suzuki Outboards 2 October 21st, 2005 08:45 PM
High Five Propellor on 1994 200HP Mariner Bob La Londe Mercury & Mariner Outboards 4 June 22nd, 2004 06:35 PM
Oil Alarm going off, 1994 200HP Mariner Mick1950 Mercury & Mariner Outboards 2 August 31st, 2003 01:58 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
