Bayliner capri 1400 with merc 700 engine ???
Tappan
Hello,
I am considering buying a '85 Bayliner Capri 1400 with a (1976?) Mercury 700 70 hp engine and matching controls installed.
I have a few questions if anyone can help with advice.
1. Is this a good combination Hull/Motor ?(no max. hp tag on hull) The seller has the original Force 50HP engine and controls he claims has only 3 seasons on it. It looks brand new. he says he removed it because he got the Merc free from his son and the Force Idled too high, says motor and boat were in storage for 15 years without running till he got it. He replaced impeller and plugs before starting.
2. What is the Force worth ($) if it passes a compression test (How many PSI should it have?)
3. Anything in particular to look for on this combo? the floor is a bit soft behind the center seat about 1.5 square foot section, but the rest of the boat is in very good shape, I didn't see any stress cracks in the gel coat especially on the transome. The motor doesn't look too bad for it's age but very nice under the cover, are these prone to any problems or too much HP for this boat? The trailer is like new.
I know it's a lot of questions for my first thread but I like to be an educated consumer! Thanks in advance for your input, Tappan
Chris1956
Re: Bayliner capri 1400 with merc 700 engine ???
Tappan, A 70HP motor is likely a bit over max for that boat. Also, turning down the fast idle on that force is a simple job, much simpler than swapping out the motor. I suspect the force may have some other issues. You might look on NADA for amy HP for that boat or c/o the Bayliner web site.
Fixing the floor can be a big job, that you will not want to pay anyone to do for you. You will need to do it yourself, or pass on the boat.
Look up the used price of the Force in the NADA as well.
