  #1
Old March 30th, 2008, 06:53 PM
mav6759 mav6759 is offline
Default 1977 115 Evinrude Compression Test
Hi guys I just got a 1977 Evinrude 115, and I wanted to do compression check on it. Does anyone know what the compression reading is for this motor? Also, I was wondering if the following procedure was correct when doing a compression check on this motor. Also, why does all the spark plug have to be remove from the motor at the start of the test, is there a reason for that or will I get a false reading testing one cylinder at a time while replacing each spark plug.
1. Remove all the spark plugs.
2. Disconnect the power supply
3. Place the throttle in the wide open position
4. Turn the motor over at least 3 rotation for each cylinder
5. Check the reading
Thanks,
Mav6759
  #2
Old March 30th, 2008, 07:09 PM
jameskb2 jameskb2 is offline
Default Re: 1977 115 Evinrude Compression Test
That's correct.
No plugs mean no compression on the other cylinders, which makes cranking easier and faster. Saves wear and tear on the starter. Pressure reading over 100 to 110 is good, 130 is better. More important, is that the cylinder pressure is close to even on all 4. Something like 100/105/110/105 or 120/125/125/120 too. 100/125/125/110 would be not as good, because one cylinder is over 10% different than the others.
  #3
Old March 30th, 2008, 07:13 PM
Ranger 330V's Avatar
Ranger 330V Ranger 330V is offline
I would say anything over 100psi is great...the main thing you are looking for is that all the numbers are within 10% of each other. I've heard of people running down into the 80's and be okay...mine is right between 95 and 100 and runs great. I would also think about using a spark tester...mainly safety sake. You want to make sure if you unhook the plug wires that the energy going to the plugs has a place to go. That will also give you a chance to check spark while you are checking compression. If your numbers are little low or a bit off from one another do a decarb...do a search for it on here and you'll find loads about it. Good luck!
__________________
"I'm your Huckleberry..." "You ain't no Daisy..."
  #4
Old March 30th, 2008, 08:08 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
agree
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old March 31st, 2008, 03:07 AM
What is the purpose of removing all the spark plugs with doing a compression test. Won't that give you a false reading. Should it be one spark plug at a time.
mav6759
  #6
Old March 31st, 2008, 04:01 AM
iwombat's Avatar
iwombat iwombat is offline
Removing all the plugs allows the motor to turn at an RPM sufficient for a reading on the hole you're measuring. If it doesn't turn fast enough, you don't get a good reading.
  #7
Old March 31st, 2008, 08:28 AM
JB's Avatar
JB JB is online now
Open throttle is not necessary.
It is a good idea to warm the engine up if possible before the check.
Turn her at least 5 turns for each cylinder, whatever it takes to get the guage to max.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1977 evinrude 85 hp bad compression in 1 cylinder Adam Olson Johnson & Evinrude Outboards 4 June 22nd, 2008 10:12 PM
Correct Compresion test? 1977, 15 hp Evinrude Chadgro Johnson & Evinrude Outboards 3 September 7th, 2007 10:34 PM
1977 15hp evinrude Compression #s high or low Chadgro Johnson & Evinrude Outboards 2 August 29th, 2007 11:45 AM
1977 Evinrude Low compression campsafe Johnson & Evinrude Outboards 2 July 17th, 2007 05:14 PM
Compression Test Question - 93 Evinrude 120 bgiles Johnson & Evinrude Outboards 6 February 1st, 2006 12:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
